field order is incorrect by reading layer definition file
All,
I'm working on offline editing in android. I created a map service with feature access on arcGis server 10.1.
I go my layer definition from JSON of my featureserver layer. I created a featurelayer based on my layer definition in my config.xml.
The offline data layer opens OK but I got inccorect field order.
Does anyone have similar issues and solutions?
Xiaoyi Zhang
Dewberry
Here's how I check the fields are in incorrect order,
projectDataFeatureLayer = new ArcGISFeatureLayer(projectDataLayerDefinition, null, layerOptions);
Field[] pField = projectDataFeatureLayer.getFields();
for (int i = 0; i < pField.length;i++)
Log.d(TAG,"Seq = " + Integer.toString(i) + " FieldName = " + pField.getAlias());
projectDataFeatureLayer.setName(projectDataName);
loadDataFromSDCard(false);
here's layer definition in my config.xml
<string name="config.projectData.layer.definition">
\"currentVersion\": 10.1,
\"id\": 0,
\"name\": \"electrical\",
\"type\": \"Feature Layer\",
\"description\": \"The feature class consists of the surveyed electrical transformers and panel point locations, required attribution, and digital photographs.\",
\"copyrightText\": \"Dewberry\",
\"defaultVisibility\": true,
\"editFieldsInfo\": null,
\"ownershipBasedAccessControlForFeatures\": null,
\"syncCanReturnChanges\": false,
\"relationships\": [],
\"isDataVersioned\": true,
\"supportsRollbackOnFailureParameter\": false,
\"supportsStatistics\": true,
\"supportsAdvancedQueries\": true,
\"geometryType\": \"esriGeometryPoint\",
\"minScale\": 0,
\"maxScale\": 0,
\"extent\": {
\"xmin\": 2605295.8095349073,
\"ymin\": 382963.4198536724,
\"xmax\": 2607622.8711894006,
\"ymax\": 386063.8142192513,
\"spatialReference\": {
\"wkid\": 102728,
\"latestWkid\": 2271
\"drawingInfo\": {
\"renderer\": {
\"type\": \"simple\",
\"symbol\": {
\"type\": \"esriPMS\",
\"url\": \"6174d66fd830441a571ea7db733c0116\",
\"imageData\": \"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\",
\"contentType\": \"image/png\",
\"width\": 10,
\"height\": 10,
\"angle\": 0,
\"xoffset\": 0,
\"yoffset\": 0
\"label\": \"\",
\"description\": \"\"
\"transparency\": 0,
\"labelingInfo\": null
\"hasM\": false,
\"hasZ\": true,
\"enableZDefaults\": false,
\"allowGeometryUpdates\": true,
\"hasAttachments\": false,
\"htmlPopupType\": \"esriServerHTMLPopupTypeAsHTMLText\",
\"objectIdField\": \"OBJECTID\",
\"globalIdField\": \"\",
\"displayField\": \"panel_id\",
\"typeIdField\": \"\",
\"fields\": [
\"name\": \"OBJECTID\",
\"type\": \"esriFieldTypeOID\",
\"alias\": \"OBJECTID\",
\"domain\": null,
\"editable\": false,
\"nullable\": false
\"name\": \"panel_id\",
\"type\": \"esriFieldTypeString\",
\"alias\": \"panel_id\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 20
\"name\": \"existing_id\",
\"alias\": \"existing_id\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 20
\"name\": \"orig_id\",
\"alias\": \"orig_id\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 20
\"name\": \"manuf_id\",
\"alias\": \"FKManufID\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 50
\"name\": \"mounting\",
\"alias\": \"mounting\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 20
\"name\": \"facil_id\",
\"alias\": \"FKFacilID\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 20
\"name\": \"floor_id\",
\"alias\": \"floor_id\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 20
\"name\": \"room_id\",
\"alias\": \"room_id\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 20
\"name\": \"feat_desc\",
\"alias\": \"feat_desc\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 60
\"name\": \"lt_desc\",
\"alias\": \"lt_desc\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 10
\"name\": \"panel_dim\",
\"alias\": \"panel_dim\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 20
\"name\": \"width\",
\"alias\": \"width\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 16
\"name\": \"depth\",
\"alias\": \"depth\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 16
\"name\": \"height\",
\"alias\": \"height\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 16
\"name\": \"no_phases\",
\"alias\": \"NoPhases\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 20
\"name\": \"main_breaker\",
\"alias\": \"main_breaker\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 20
\"name\": \"amp_rate\",
\"type\": \"esriFieldTypeSmallInteger\",
\"alias\": \"AmpRate\",
\"domain\": null,
\"editable\": true,
\"nullable\": true
\"name\": \"voltage_d\",
\"alias\": \"VoltageDOM\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 16
\"name\": \"hertz_d\",
\"alias\": \"HertzDOM\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 16
\"name\": \"no_circuit\",
\"type\": \"esriFieldTypeInteger\",
\"alias\": \"no_circuit\",
\"domain\": null,
\"editable\": true,
\"nullable\": true
\"name\": \"use_circuit\",
\"alias\": \"use_circuit\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 5
\"name\": \"serial_no\",
\"alias\": \"SerialNo\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 15
\"name\": \"coord_id\",
\"alias\": \"FKCoordID\",
\"domain\": null,
\"editable\": true,
\"nullable\": true,
\"length\": 20
\"types\": [],
\"templates\": [
\"description\": \"\",
\"prototype\": {
\"attributes\": {
\"coord_id\": null,
\"panel_id\": null,
\"existing_id\": null,
\"orig_id\": null,
\"manuf_id\": null,
\"mounting\": null,
\"facil_id\": null,
\"floor_id\": null,
\"room_id\": null,
\"feat_desc\": null,
\"lt_desc\": null,
\"panel_dim\": null,
\"width\": null,
\"depth\": null,
\"height\": null,
\"no_phases\": null,
\"main_breaker\": null,
\"amp_rate\": null,
\"voltage_d\": null,
\"hertz_d\": null,
\"no_circuit\": null,
\"use_circuit\": null,
\"serial_no\": null
\"drawingTool\": \"esriFeatureEditToolPoint\"
\"maxRecordCount\": 1000,
\"supportedQueryFormats\": \"JSON, AMF\",
\"capabilities\": \"Create,Delete,Query,Update,Uploads,Editing\"
</string>
