Hi there, I tried to using Utilitysolution.py to import access .mdb file.
Below is my script modified from CCTV Manager's page Import Access Tables—Tool Reference | ArcGIS Solutions :
# Name: ImportAccessTables.py
# Description: Converts tables in an Access database to file geodatabase.
# Import required modules
import arcpy
# Local Variables
mdb = "K:\\GIS_Folder\\Data\\Well_Reports.mdb"
tables = ['Wells', 'Well_Reports']
out_folder_path = "K:\\GIS_Folder\\Data\\Waterwells"
out_name = "Well_Reports_converted"
import_type = "DATA"
arcpy.utilsol.ImportAccessTables(mdb,
tables,
out_folder_path,
out_name,
import_type)
But I have runtime error that I do not know how to solve:
RuntimeError Traceback (most recent call last)
In [5]:
Line 18: import_type)
File C:\Users\tchung\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\utilsolutions\esri\arcpy\UtilitySolutions.py, in ImportAccessTables:
Line 44: [mdb, tables, out_folder_path, out_name, import_type])
File C:\Users\tchung\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\utilsolutions\esri\arcpy\UtilitySolutions.py, in _runner:
Line 17: raise e
Line 15: return convertArcObjectToPythonObject(func(*gp_fixargs(args, True)))
File c:\users\tchung\appdata\local\programs\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py, in <lambda>:
Line 511: return lambda *args: val(*gp_fixargs(args, True))
RuntimeError: Object: Error in executing tool---------------------------------------------------------------------------
