I'm having trouble setting an output parameter of type "Feature Set" in a python toolbox. Here's what I have currently:
import arcpy
class Toolbox(object):
def __init__(self):
self.label = "FeatureSet Output Test"
self.alias = ""
self.tools = [Test]
class Test(object):
def __init__(self):
self.label = "Test1"
self.description = "Output a few points in a feature set"
self.canRunInBackground = False
def getParameterInfo(self):
params = []
param0 = arcpy.Parameter(
displayName = "FS Output", name = "fsOutput",
datatype = "Feature Set", parameterType = "Derived", direction = "Output")
params.append(param0)
param1 = arcpy.Parameter(
displayName = "JSON Output", name = "strOutput",
datatype = "String", parameterType = "Derived", direction = "Output")
params.append(param1)
return params
def execute(self, parameters, messages):
gdbPath = 'in_memory'
featureClassName = 'points'
featureClass = '{}/{}'.format(gdbPath, featureClassName)
try:
arcpy.AddMessage('Creating a point feature class with 1 text attribute')
if arcpy.Exists(featureClass):
arcpy.Delete_management(featureClass)
arcpy.CreateFeatureclass_management(
out_path=gdbPath, out_name=featureClassName, geometry_type='POINT',
spatial_reference=arcpy.SpatialReference(4326))
arcpy.AddField_management(
in_table=featureClass,
field_name='Attribute1', field_type='TEXT')
arcpy.AddMessage('Inserting a couple points')
with arcpy.da.InsertCursor(featureClass, ('SHAPE@XY', 'Attribute1')) as cur:
cur.insertRow(((1, 1), 'point at 1, 1'))
cur.insertRow(((2, 2), 'point at 2, 2'))
arcpy.AddMessage('Setting the output parameters')
featureSet = arcpy.FeatureSet(featureClass)
parameters[0].value = featureSet
parameters[1].value = featureSet.JSON
except Exception as e:
arcpy.AddError(str(e))
The first output parameter displays as "empty"; if I print paramers[0].value it will output "None" ..The second TEXT parameter seems to work fine; I get the following output:{"displayFieldName":"","fieldAliases":{"OID":"OID","Attribute1":"Attribute1"},"geometryType":"esriGeometryPoint","spatialReference":{"wkid":4326,"latestWkid":4326},"fields":[{"name":"OID","type":"esriFieldTypeOID","alias":"OID"},{"name":"Attribute1","type":"esriFieldTypeString","alias":"Attribute1"}],"features":[{"attributes":{"OID":1,"Attribute1":"point at 1, 1"},"geometry":{"x":1.0000000000000568,"y":1.0000000000000568}},{"attributes":{"OID":2,"Attribute1":"point at 2, 2"},"geometry":{"x":2.0000000000000568,"y":2.0000000000000568}}]}
Anyone know why this doesn't work?Thanks in advance 🙂
