Hey Mike,The Collector app can only be accessed by users within a AGOL Organization and Portal account. I just set up a test trial account and I was able to login with that account once my organization was set up. Make sure your global account you are using is now a user, publisher or admin within the trial org you have set up.CheersRuss
Ok, I understand that I must have an organizational account and I do. For example EPA's url is: epa.maps.arcgis.com. However, I'm getting the same error. Any ideas?
@JoyStraleyThe free account that you have with ArcGIS Online will not work with the Collector app. It will work with the ArcGIS for iOS/Android/WP apps. The only way to set up your account to become an Admin/Publisher/User is to start up a ArcGIS Online Subscription. This 60 min seminar can help you out with understanding what the ArcGIS Online subscriptions are: http://training.esri.com/gateway/index.cfm?fa=catalog.webCourseDetail&courseid=2498@btecinicOnce you buy full ArcGIS Online subscription or start up a trial subscription you will receive an email that will let you activate the subscription.I would also recommend checking out the ArcGIS Online forums and posting your questions for subscription start up and setup there.Hope this helps you out.Russ
I use ArcGIS at my university. My university has the full version but I can't find the portal to sign into Collector. I looked in ArcGIS Administrator and just found : http://www.arcgis.com. I've contacted computer services and the professor with the licensing information. They don't know anything beyond what I've already done.
I need to use Collector and can't get to it.
What should I do next?
Donna,
You will need to download the Collector for ArcGIS App for whatever device you are using, (iOS, Android, etc), from their respective App Store.
Once you have the app downloaded you will just open the app and use your login credentials for your organization.
Los miembros registrados pueden publicar, seguir actualizaciones y más. ¿Nuevo aquí? Regístrate gratis.
