I am trying to deploy a default ArcGIS QT Quick project into a macOS Mojave. The ArcGISQTQuick.app runs fine on my development Mac from the build folder. On the target Mac, the app runs for a split second and exits.
I went through the Mac logs in the console applications and came across the following errors.
ArcGISQTQuick: QQmlApplicationEngine failed to load component
ArcGISQTQuick: qrc:/qml/main.qml:16 module "Esri.ArcGISRuntime" is not installed
Following .pri files are added to my ArcGISRuntime.pri.
!include($$priLocation/sdk/ideintegration/arcgis_runtime_qml.pri) { message("Error. Cannot locate ArcGIS Runtime PRI file")}
!include($$priLocation/sdk/ideintegration/esri_runtime_qt.pri) { message("Error. Cannot locate ArcGIS Runtime PRI file")}
I thought addition of those lines would have handled the .qml import paths. Is there anything else I should be doing? It seems that .qml files for Esri are not being linked/imported correctly to the deployment folder of the app.
As for the kit, I use Desktop QT 5.12.2 clang 64bit with release option.
Best,
Selim Ozel
