I am preforming a weighted overlay. All of my raster's are in 1 folder. There are 4 different rasters that will be used in the weighted model (s,v,o,l)
1 run through will use 4 raster's with 0520a as the example code (I have 75 or so codes of rasters in 1 folder)
s0520a
v0520a
o0520a
l0520a
I need to find a way to select a code and loop through each 5 digit code code and add the s,v,o,l to the model then move on to the next code. If this was using a search cursor I would just set for r[0] but I'm not sure how to do that for looping through rasters. Also not sure how to create the output raster (send the code variable to the output name I suppose)
Thanks in advance!
Here is what I have so far:
import arcpy
arcpy.CheckOutExtension("spatial")
arcpy.overwriteOutput = True
inrcras = "C:\\Risk2014\\TestReclass\\"
arcpy.env.workspace = "C:\\Risk2014\\TestReclass"
rcras = sorted(arcpy.ListRasters())
outras = "C:\\Risk2014\\TestWeighted\\w"
for r in rcras:
print r[4:] #code isolated for iterating
if r[1] == "s":
s = inrcras + r
if r[1] == "v":
v = inrcras + r
if r[1] == "o":
o = inrcras + r
if r[1] == "l":
l = inrcras + r
print s, v, o, l
#arcpy.gp.WeightedOverlay_sa("(s 25 VALUE (1 1; 2 2; 3 3; 4 4; 5 5; 6 6; 7 7; 8 8; 9 9; NODATA NODATA); v 25 VALUE (1 1; 2 2; 3 3; 4 4; 5 5; 6 6; 7 7; 8 8; 9 9; NODATA NODATA); o 25 VALUE (1 1; 2 2; 3 3; 4 4; 5 5; 6 6; 7 7; 8 8; 9 9; NODATA NODATA); l 25 VALUE (1 1; 2 2; 3 3; 4 4; 5 5; 6 6; 7 7; 8 8; 9 9; NODATA NODATA));1 9 1", outras + ?)
del r, rcras
