I am using a modified version of script # 3 from the help docs here to update several services each day. Data is copied to the server for this. My modification is only that I loop through several MXD files, so basically just a for loop wrapper around the script at the end of the post here.
The issue is that the arcpy.StageService creates a .sd file as well as folders containing a copy of the data it will upload to the server. As far as I can tell, there is no provision to have this tool clean up after itself after uploading the service.It is trivial to delete the SD file, but the copy of the data I am not sure about. It is placed in folders 0, 1, 2, ...This does not seem to be well documented.
Is there something I am missing? Does anyone know of a reliable way to clean up after this tool, so I don't accumulate copies of my data over time?
<SPAN class="comment token"># Name: StageService_example3_UploadServiceDefinition_example4.py</SPAN>
<SPAN class="comment token"># Description: Creates a service definition that can be used to overwrite an </SPAN>
<SPAN class="comment token"># existing service. When this service definition is published it </SPAN>
<SPAN class="comment token"># will overwrite the existing service.</SPAN>
<SPAN class="comment token"># Requirements: Connection to an ArcGIS Server or My Hosted Services</SPAN>
<SPAN class="comment token"># Import system modules</SPAN>
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">from</SPAN> arcpy <SPAN class="keyword token">import</SPAN> env
<SPAN class="keyword token">import</SPAN> xml<SPAN class="punctuation token">.</SPAN>dom<SPAN class="punctuation token">.</SPAN>minidom <SPAN class="keyword token">as</SPAN> DOM
<SPAN class="comment token"># Set environment settings</SPAN>
env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:/data"</SPAN>
<SPAN class="comment token"># Set local variables</SPAN>
inServiceDefinitionDraft <SPAN class="operator token">=</SPAN> <SPAN class="string token">"myMapService.sddraft"</SPAN>
outServiceDefinition <SPAN class="operator token">=</SPAN> <SPAN class="string token">"myMapService.sd"</SPAN>
newType <SPAN class="operator token">=</SPAN> <SPAN class="string token">'esriServiceDefinitionType_Replacement'</SPAN>
xml <SPAN class="operator token">=</SPAN> draftPath <SPAN class="operator token">+</SPAN> in_sd_draft
doc <SPAN class="operator token">=</SPAN> DOM<SPAN class="punctuation token">.</SPAN>parse<SPAN class="punctuation token">(</SPAN>xml<SPAN class="punctuation token">)</SPAN>
descriptions <SPAN class="operator token">=</SPAN> doc<SPAN class="punctuation token">.</SPAN>getElementsByTagName<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Type'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> desc <SPAN class="keyword token">in</SPAN> descriptions<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> desc<SPAN class="punctuation token">.</SPAN>parentNode<SPAN class="punctuation token">.</SPAN>tagName <SPAN class="operator token">==</SPAN> <SPAN class="string token">'SVCManifest'</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> desc<SPAN class="punctuation token">.</SPAN>hasChildNodes<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
desc<SPAN class="punctuation token">.</SPAN>firstChild<SPAN class="punctuation token">.</SPAN>data <SPAN class="operator token">=</SPAN> newType
outXml <SPAN class="operator token">=</SPAN> xml
f <SPAN class="operator token">=</SPAN> open<SPAN class="punctuation token">(</SPAN>outXml<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'w'</SPAN><SPAN class="punctuation token">)</SPAN>
doc<SPAN class="punctuation token">.</SPAN>writexml<SPAN class="punctuation token">(</SPAN> f <SPAN class="punctuation token">)</SPAN>
f<SPAN class="punctuation token">.</SPAN>close<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Execute StageService</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>StageService_server<SPAN class="punctuation token">(</SPAN>inServiceDefinitionDraft<SPAN class="punctuation token">,</SPAN> outServiceDefinition<SPAN class="punctuation token">)</SPAN>
inSdFile <SPAN class="operator token">=</SPAN> outServiceDefinition
inServer <SPAN class="operator token">=</SPAN> <SPAN class="string token">"GIS Servers/myServerConnection"</SPAN>
<SPAN class="comment token"># Execute UploadServiceDefinition</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>UploadServiceDefinition_server<SPAN class="punctuation token">(</SPAN>inSdFile<SPAN class="punctuation token">,</SPAN> inServer<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
