I have a, hopefully, basic question. I have buffered lines connected to points from which I have then clipped from a vegetation and land use characterization layer that I converted from a raster to a polygon in order to do the clipping and get areas of each vegetation type within the buffered lines and points.
I have successfully clipped the points but I want to know if there is a way I can get the information contained in just the line portion and exclude what is in the buffered. I've tried using the clipping tool but I cannot figure out how to just get the line portion and not the point portion of the polygon (i.e. Basically clip the points from the line and get the habitat information contained in the lines.
Let me know if you need any more information, thank you in advance!
