System: Windows Vista and ArcGIS 9.3Hello, I have 100 shapefiles called geocXXXX.shp (geoc0782, geoc9838, and geoc6728 etc)In each shapefile, there is a field call CXXXX (C0782, C9838, and C6728 etc).The field property is string, length =6.Now I would like to make a new field call CXXXXD (C0782D, C9838D, and C6728D etc).The field property is long integer, length =9.Please kindly advise how to modify the follow code and thank you.##Script Name: Copy field ##Description: Copy field using CXXXX ##Created By: Elaine Kuo ##Date: 06/25/2013 #Import standard library modules import arcgisscripting import os #Create the Geoprocessor object gp = arcgisscripting.create(9.3) #Set the input workspace #GP.workspace = sys.argv[1] #Set the workspace. gp.Workspace= "H:/temp_D/test" #Set the output workspace #outWorkspace = sys.argv[2] #Set the workspace. List all of the feature classes in the dataset outWorkspace= "H:/temp_D" #Get a list of the featureclasses in the input folder fcs = gp.ListFeatureClasses() # Loop through every item in the list that was just generated for fc in fcs: # Break out the name, no path or extension, using the describe object. desc = gp.describe(fc) featureName = desc.name #Validate the new feature class name for the output workspace. OutFeatureClass = outWorkspace + os.sep + gp.ValidateTableName(fc,outWorkspace) #get file name fcName, fcExt = os.path.splitext(fc) # Get a list of the fields in the featureclass fields = gp.listFields(fc, "C*", "String") # replace the strings you want to fcName = fcName.replace("D","") fcName = fcName + fcExt fcName = outWorkspace + os.sep + fcName #get file name fcName, fcExt = os.path.splitext(fc) fieldName = fcName + "D" #build field name #Add field to each SHP gp.AddField_management(fc, fieldName, "LONG", 9, 3)
