Dear Gurus !There is a table events with fields X, Y - containing the coordinates of points, which must be registered in the geodatabase. Created geodatabase cuks_gdb with standard tools of arcgis desktop 10.1. Table events copied in geodatabase :select * into cuks_gdb.sde.events from cuks.dbo.events
3 . In the cloned table added field "shp" type geometry.4 . Formed a field value by field values �??�??x, y:update cuks_gdb.sde.events set Shp = geometry :: STGeomFromText ('Point (' + ltrim (STR (x, 99, 11 )) + '' + ltrim (STR (y, 99, 11) ) + ')' , 28406 );All formed , error messages were not. But when I try to save changes in any field then I get an error messageThe parameter type cuks_gdb.sys.geometry is invalid. Parameter name: valueHow to fix ?
