I used the sample "findnearbyfeaturessoapsoe" to create a Java SOAP enabled Server Object Extension with the Eclipse plugin but the build ends with: "javac terminated with errors". As this is not very informative I went to the commandline utility "soepackager" in the developerkit. This put out the following stacktrace:Port Class .\release\JavaFindNearbyFeaturesSOAPSOE\stubs\arcgissamples\soe\IJavaFindNearbyFeatures.class
Working on File : IJavaFindNearbyFeatures.java
Created Port Classes
Service Class .\release\JavaFindNearbyFeaturesSOAPSOE\stubs\arcgissamples\soe\JavaFindNearbyFeaturesSOAPSOEService.class
Working on File : JavaFindNearbyFeaturesSOAPSOEServiceBindingStub.java
Created Service Class
Generated Stub classes in .\release\JavaFindNearbyFeaturesSOAPSOE\stubs\
release\JavaFindNearbyFeaturesSOAPSOE\stubs\arcgissamples\soe\IJavaFindNearbyFeatures.java:9: error: variable arg is alr
eady defined in method findNearbyFeatures
public com.esri.arcgisws.RecordSet findNearbyFeatures (int arg, Point arg, double arg);
release\JavaFindNearbyFeaturesSOAPSOE\stubs\arcgissamples\soe\JavaFindNearbyFeaturesSOAPSOEServiceBindingStub.java:18: e
rror: variable arg is already defined in method findNearbyFeatures
public com.esri.arcgisws.RecordSet findNearbyFeatures (int arg, Point arg, double arg) {
release\JavaFindNearbyFeaturesSOAPSOE\stubs\arcgissamples\soe\JavaFindNearbyFeaturesSOAPSOEServiceBindingStub.java:20: e
rror: cannot find symbol
((FindNearbyFeatures)object).setArg(arg);
symbol: method setArg(double)
release\JavaFindNearbyFeaturesSOAPSOE\stubs\arcgissamples\soe\JavaFindNearbyFeaturesSOAPSOEServiceBindingStub.java:21: e
release\JavaFindNearbyFeaturesSOAPSOE\stubs\arcgissamples\soe\JavaFindNearbyFeaturesSOAPSOEServiceBindingStub.java:22: e
7 errors
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.esri.arcgis.tools.SOEPackager.generateStubs(SOEPackager.java:664)
at com.esri.arcgis.tools.SOEPackager.processSoes(SOEPackager.java:423)
at com.esri.arcgis.tools.SOEPackager.main(SOEPackager.java:955)
Caused by: java.lang.RuntimeException: "javac" terminated with errors.
at com.esri.arcgis.server.StubGen.invokeCommand(Unknown Source)
at com.esri.arcgis.server.StubGen.createAndRefactorStubs(Unknown Source)
at com.esri.arcgis.server.StubGen.generateStubs(Unknown Source)
at com.esri.arcgis.server.StubGen.main(Unknown Source)
It looks like that the method in the generated file IJavaFindNearbyFeatures.java has parameters with equal names "arg" and the compiler will not accept that.Has anyone encountered this same problem? And if so, what was your solution to fix it?My developer tools are:Eclipse JunoJava 1.7.0.51 (64 bit)ArcGIS 10.2.0 and 10.2.1Thanx in advance!Freddy
