As per my tongue twister subject I am trying to work with MapImageLayer objects and their sub layers in V4 of the JS API.
I have hydrated a web map into a map object. The web map has a map service (/MapServer), which is hydrated, naturally, to a MapImageLayer object.
However, despite the map service having sub layers, they are not available to the layer object. At least this is what I surmise by interrogating the layer object’s allSubLayers property, which is empty.
I feel like I'm missing a trick here. The API reference talks about working with sub layers but only when defined by the programmer, not coming from a web map.
Ultimately, I aim to set layer definition queries on the sub layers but just need to get those layer objects before queries can be applied.
I have created a test harness below, which illustrates my conundrum:
<SPAN class="operator token"><</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1,maximum-scale=1,user-scalable=no"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Load a basic WebMap <SPAN class="operator token">-</SPAN> <SPAN class="number token">4.11</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN>
html<SPAN class="punctuation token">,</SPAN>
body<SPAN class="punctuation token">,</SPAN>
#viewDiv <SPAN class="punctuation token">{</SPAN>
padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.11/esri/themes/light/main.css"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.11/"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/WebMap"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/config"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/LayerList"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>MapView<SPAN class="punctuation token">,</SPAN> WebMap<SPAN class="punctuation token">,</SPAN>
esriConfig<SPAN class="punctuation token">,</SPAN> LayerList<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> webmap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">WebMap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
portalItem<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// autocasts as new PortalItem()</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"90613226a9bc41998a1c893d596badc8"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
webmap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> allLayersAndSublayers <SPAN class="operator token">=</SPAN> webmap<SPAN class="punctuation token">.</SPAN>allLayers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">flatten</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> item<SPAN class="punctuation token">.</SPAN>layers <SPAN class="operator token">||</SPAN> item<SPAN class="punctuation token">.</SPAN>sublayers<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> layerList <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">:</SPAN> view
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>layerList<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
position<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"top-left"</SPAN>
<SPAN class="comment token">/************************************************************
* Set the WebMap instance to the map property in a MapView.
************************************************************/</SPAN>
<SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
map<SPAN class="punctuation token">:</SPAN> webmap<SPAN class="punctuation token">,</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
