I want to create a table called "Test" from inputTable called "Avg_Daily" using arcpy.MakeQueryTable_Management option of arcpy. However, I am getting error which says "Error 999999: An Invalid SQL statement was used". I don't know where I used invalid SQL statement. Any idea? Here is the code:import arcpy from arcpy import env env.workspace ="C:/RG/Projects/CriticalDataNetwork/CDEC.gdb" try: inTable = "Avg_Daily" keyField = "STATION_ID" inField = [["Avg_Daily.OBJECTID","OBJECTID",],["Avg_Daily.STATION_ID","STATION_ID"], ["Avg_Daily.DLY_AVG", "DLY_AVG"]] whereClause = "\"STATION_ID\" = 'CAP', 'DDM'" outTable = "Test" arcpy.MakeQueryTable_management(inTable, outTable, "USE_KEY_FIELDS", keyField, inField, whereClause) except Exception, e: # If an error occurred, print line number and error message import traceback, sys tb = sys.exc_info()[2] print "Line %i" % tb.tb_lineno print e.message
