Hello All,
I am new to coding in general and trying to get print task to work with the print widget button.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<title>Print widget - 4.10</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.10/esri/css/main.css">
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
overflow: hidden;
</style>
<script src="https://js.arcgis.com/4.10/"></script>
<script>
require([
"esri/views/MapView",
"esri/widgets/Print",
"esri/WebMap",
"esri/tasks/PrintTask",
"esri/tasks/support/PrintTemplate",
"esri/tasks/support/PrintParameters"
function(
MapView, Print, WebMap, PrintTask, PrintTemplate, PrintParameters
var webmap = new WebMap({
portalItem: { // autocasts as new PortalItem()
var view = new MapView({
container: "viewDiv",
map: webmap
view.when(function(){
var print = new Print({
view: view,
// specify your own print service
var printTask = new PrintTask({
url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task"
view.ui.add(print, "top-right");
var template = new PrintTemplate({
format: "jpg",
exportOptions: {
dpi: 300
layout: "a4-landscape",
layoutOptions: {
titleText: "Test",
authorText: "Carson",
forceFeatureAttributes: true,
showLabels: true,
Preservescale: true,
var params = new PrintParameters({
view: view,
template: template
const printResult = result => window.open(result.url, "_blank")
const printError = error => console.log(error)
printTask.execute(params).then(printResult, printError);
</script>
</head>
<body class="calcite">
<div id="viewDiv"></div>
</body>
</html>
Im unsure how to "combine" the two. Thank you.
