Hi There,
I have been looking at using the Esri ArcGIS api. I haven't done dojo before and have run into an issue.
Im looking at using the basemapGallery, when isolated this works fine:
var map;
require([
"esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
"dojo/domReady!"
], function(
Map, BasemapGallery, arcgisUtils
map = new Map("map", {
basemap: "topo",
center: [-105.255, 40.022],
zoom: 13
//add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
var basemapGallery = new BasemapGallery({
showArcGISBasemaps: true,
map: map
}, "basemapGallery");
basemapGallery.startup();
basemapGallery.on("error", function(msg) {
console.log("basemap gallery error: ", msg);
but when I combine it with my code i get the following error "Uncaught Error: Target must be an event emitter"
var map;
require([
"esri/map", "esri/InfoTemplate", "esri/Color", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/ImageParameters", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
"dojo/dom", "dojo/dom-class", "dojo/dom-construct", "dojo/on", "dojo/query", "dojo/domReady!" ],
function(
Map, InfoTemplate, Color, ArcGISDynamicMapServiceLayer, ImageParameters, dom, domClass, domConstruct, on, query, BasemapGallery, arcgisUtils
var layer, visibleLayerIds = [];
center: [ -0.181710, 52.328117 ],
zoom: 12,
basemap: "osm",
infoWindow: infoWindow
map: map
MORE CODE....
Any help, or suggestions towards the solution would be gratefully recieved. Let me know if you need any more information.
Trevor
