Hello;
I want to create a widget with a function (function _invoqueWS) that retrieves data from a web service REST JSON with esriRequest.
This function must be invoked from other functions of the widget (startup función for example an others).
I created the following functions but when I try to return the JSON content variable, the variable in the startup function is undefined or null. I have also tried to initialize a global variable in the function _invoqueWS and recover the value in function startup , but without results. What am I doing wrong. In the invoqueWS function the JSON data is correct.
I am using API 3.17 javascript
Thank you very much, greetings.
startup: function()
//other code
var resultado= this_ invoqueWS ();
//other code
_invoqueWS: function() {
var resultado
var url_servicio="xyz";
var layersRequest = esriRequest({
url: url_servicio,
handleAs: "json",
load: function (result)
resultado = result.ElementosEstacionOutput[0].ID_ESTADOS_INST_EXPRESION;
error: function (error)
resultado= error;
return resultado
