I have a bunch of .lyr files that point to a directory that's been moved. I'm trying to programmatically re-link them to the new location (hopefully to a UNC location like \\server\folder instead of W:\folder)so my code looks like this: import arcpy, sys, os, fnmatch
dir = sys.argv[1] # directory to search
old = sys.argv[2] # old feature class path/name to replace
new = sys.argv[3] # new feature class path/name
# go to the directory and get a list of the files
filelist = os.listdir(dir)
# get that file list and for each name....
for filename in filelist:
# look for any .lyr files
if fnmatch.fnmatch(filename, '*.lyr'):
arcpy.AddMessage(filename + " is a layer file")
# create a layer object from the .lyr file
lyrfile = arcpy.mapping.Layer(dir + '\\' + filename)
arcpy.AddMessage(filename + " is now a layer object")
arcpy.AddMessage(old)
arcpy.AddMessage(new)
lyrfile.findAndReplaceWorkspacePath(old, new)
arcpy.AddMessage("fixed data source")
arcpy.AddMessage("finito!!!")
del filename, filelist, dir, old, new, lyrfile
but when I run it - I get messages saying that something is happenning (all my addMessages). But when it comes to actually re-mapping my datasource, well, nothing happens. When I re-add the .lyr files to my mxd and check the data source, it doesn't change. It's still the old datasource. any help???
