Thanks for looking at my question. From searching on the internet either this cannot be done, or what code I find does not work. It shows the VB.net side, but not what has to be done on the Python side.
This should be simple, I have a form in VB.net where the user selects an excel file to be converted to a dbf file then added to a geodatabase. I can hard code the file and geodatabase name into my python script and it works fine. I can run the script (with the hard coded names within) from my VB.net form, works fine.
What I want to do is when the user selects a file name from the listbox, that file name is then sent to the Python script as a variable when the script is called from VB.net. Then within the Python script it picks up that variable.
Am I even close as to how I think this should work. Dale,
