Running Portal for ArcGIS 10.5.1, on Windows 2016; no WebAdaptor, but using Enterprise and ArcGIS authentication on Portal
Have 2 federated servers behind a proxy as well and fullBackupSite operation fails on both. I've changed the logging level in logging.properties which is in the same directory as webgisdr.bat, but I don't seem to get any other messages but FINER, SEVERE, and a few INFOs.
The first error (reported in a FINER statement seems to be after the call to getBaseBackkupTimeStamp; since it's a FINER message, not sure if this is actually a problem.
The main error is related to not creating a backup directory. I've confirmed that the account running the webgisdr.bat has write access to this directory. I've confirmed that the service account running Portal has access to this directory.
I'm also assuming the token is ok because there is no error after the getServerToken call
Question: Is the JSON response issue necessary to fix first?
Question: what other aspects of creating the backup folder should I explore?
Oct 22, 2019 3:11:32 PM com.esri.arcgis.webgis.util.WebGISUtil getBaseBackupTimeStamp
FINER: {"code":500,"messages":["Error while processing request. Internal error. JSON response not set."],"status":"error"}
Oct 22, 2019 3:11:33 PM com.esri.arcgis.webgis.util.WebGISUtil getServerToken
FINER: {"owningSystemUrl":"https://<portal_url_Proxy>/arcgis","fullVersion":"10.5.1","secureSoapUrl":null,"soapUrl":"https://gisd24.dot.nc.net/arcgis/services","currentVersion":10.51,"authInfo":{"tokenServicesUrl":"https://<portal_url_Proxy>/arcgis/sharing/generateToken","isTokenBasedSecurity":true}}
FINER: {"owningSystemUrl":"https://<portal_url_Proxy>/arcgis","fullVersion":"10.5.1","secureSoapUrl":null,"soapUrl":"https://<federated_server_url_internal>/arcgis/services","currentVersion":10.51,"authInfo":{"tokenServicesUrl":"https://<portal_url_Proxy>/arcgis/sharing/generateToken","isTokenBasedSecurity":true}}
Oct 22, 2019 3:11:37 PM com.esri.arcgis.webgis.product.Server fullBackupSite
SEVERE: Failed to back up the ArcGIS Server.
Admin Url: https://<federated_server_url_Proxy>/arcgis/admin.
SEVERE: {"code":500,"messages":["Export operation failed. Failed to create the folder 'D:\\PortalBackupShare\\WebGISSite1571771489332\\server\\t4b1j9y2kxo2kw9t'."],"status":"error"}
