I'm trying to use the arcpy module in functions that are within custom Python modules that I've created, but I keep getting this error:
NameError: global name 'arcpy' is not defined
How do I fix this? These modules will be used within ArcGIS, where ArcPy is already loaded.
I've tried with and without "import arcpy".
Example:
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">refresher</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">''' Refreshes map and TOC '''</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>RefreshActiveView<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>RefreshTOC<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="string token">'Refreshed map and TOC.'</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
