I started to replace my bootstrap layout with the suggested layout examples using dojo but not having much luck.I started with "Layout with right pane, map data from ArcGIS.com". The live link works in my browser but when I transfer it to my localhost server it fails to display anything. I downloaded the layout.css file and that is loading. In both the online example and on my localhost the SoriaGrid.css resource fails to load but I assume that is OK (but should be changed in the demo). I have attempted to merge my code with the example. In my best attempt I get the right pane at the bottom. My code is shown below and I could use a pointer where the layout has gone wrong. I am guessing that I am requiring the dijit resources incorrectly but I cannot figure out the syntax for including them. In my worst attempt I get no reference to dojo at the dojo.require lines.I am using chrome as the browser.<!DOCTYPE html> <html> <head> <title></title> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/soria/soria.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dojox/grid/resources/Grid.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dojox/grid/resources/SoriaGrid.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css"> <link rel="stylesheet" href="Content/layout.css"> <script> // Instead of using data-dojo-config, we???re creating a dojoConfig object // *before* we load dojo.js; they???re functionally identical. var dojoConfig = { async: true, // This code registers the correct location of the "demo" package // so we can load Dojo from the CDN whilst still being able to // load local modules paths: { extras: location.pathname.replace(/\/[^/]*$/, '') + "/scripts/dojo" } }; </script> <script src="http://js.arcgis.com/3.7/"></script> <script> // dojo.require("dijit.layout.BorderContainer"); //dojo.require("dijit.layout.ContentPane"); //dojo.require("esri.map"); //dojo.require("esri.IdentityManager"); //dojo.require("esri.arcgis.utils"); var map; require(["esri/map","dojo/domReady!"], function (Map) { map = new Map("mapDiv", { center: [-56.049, 38.485], zoom: 3, basemap: "streets" }); dojo.byId("title").innerHTML = "Right Side Demo"; // mapDeferred.then(function (response) { // map = response.map; // dojo.byId("title").innerHTML = response.itemInfo.item.title; // dojo.byId("dataSource").innerHTML = "<a target='_blank' href='http://www.arcgis.com/home/item.html?id=" + webmap + "'>View data details</a>"; //}, function (error) { // console.log("Map creation failed: ", dojo.toJson(error)); // }); }) //show map on load // dojo.ready(init); </script> </head> <body class="soria"> <div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;"> <div id="header" data-dojo-type="dijit.layout.ContentPane" class="roundedCorners" data-dojo-props="region:'top'"> <div id="title"></div> </div> <div id="mapDiv" data-dojo-type="dijit.layout.ContentPane" class="roundedCorners" data-dojo-props="region:'center'"> </div> <div data-dojo-type="dijit.layout.ContentPane" id="rightPane" class="roundedCorners" data-dojo-props="region:'right',splitter:'true'"> Right section </div> <div id="footer" class="roundedCorners" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'bottom'"> <span id="dataSource"></span> </div> </div> </body> </html>
