When I'm using a esri javascript renderer on a dynamic map service (e.g. ClassBreaksRenderer or UniqueValueRenderer), is there any way to set the symbol levels (i.e. drawing order) for each break/value?
For example:
<SPAN class="keyword token">var</SPAN> renderer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">UniqueValueRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> none<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> low<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN> medium<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN> high<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Where, "none", "low", "medium", and "high" are SimpleMarkerSymbols, how can I ensure that the high (4) points always are on top of the medium (3), low (2) and none (1) points?
If I publish a service with the symbol levels defined in ArcMap, it obeys the symbol levels, but I want to be able to change the renderer dynamically and still obey the symbol levels.
Any ideas?
