In ArcGIS Advanced for Desktop 10.2, I am trying to calculate a field "ELEV_METER" in a shapefile with an expression and code-block as here:
expression = "getElev(double(!ELEV!))" codeblock = """def getElev(elev): if elev <> 0: return !ELEV!""" arcpy.CalculateField_management(fc, "ELEV_METER", expression, "PYTHON_9.3",codeblock)
trying to apply ressources from ESRI:
http://resources.arcgis.com/en/help/main/10.1/index.html#//00170000004m000000
The calculate field should be done only if the field ELEV is not 0, then the if statment...
But is does not work! Any guess?
Cheers
