I building building a basic application with the ESRI javascript API 3.24, accepting that I don't have ArcGIS Server or AGO, is there any approach to add nearby geojson record to the guide, this inquiry had been asked commonly.
I don't have to utilize Terraformer. I am attaching my geojson document and the code I have up until now, there is no error, yet geojson isn't appearing in the map.
In the event that there is an answer for this would i be able to apply it on WAB, or is there any out of box widget to add local geojson file to the map (on map load ).
<SPAN class="doctype token"><!DOCTYPE html></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">charset</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>utf-8<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>viewport<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">content</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>initial-scale<SPAN class="punctuation token">=</SPAN>1,maximum-scale<SPAN class="punctuation token">=</SPAN>1,user-scalable<SPAN class="punctuation token">=</SPAN>no<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>FeatureLayer<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>link</SPAN> <SPAN class="attr-name token">rel</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>stylesheet<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fjs.arcgis.com%2F3.24%2Fesri%2Fcss%2Fesri.css" target="_blank">http://js.arcgis.com/3.24/esri/css/esri.css</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fjs.arcgis.com%2F3.24%2F" target="_blank">http://js.arcgis.com/3.24/</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="comment token"><!--<script src="travel6.json" type="text/javascript"></script> --></SPAN>
<SPAN class="language-css style token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="selector token">html, body, #map</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">padding</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">margin</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleMarkerSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Color"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/renderers/SimpleRenderer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleFillSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleLineSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/FeatureSet"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/request"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/Polygon"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/graphic"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/on"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/_base/array"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/domReady!"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>
Map<SPAN class="punctuation token">,</SPAN> SimpleMarkerSymbol<SPAN class="punctuation token">,</SPAN> Color<SPAN class="punctuation token">,</SPAN> SimpleRenderer<SPAN class="punctuation token">,</SPAN> SimpleFillSymbol<SPAN class="punctuation token">,</SPAN>SimpleLineSymbol<SPAN class="punctuation token">,</SPAN>
FeatureSet<SPAN class="punctuation token">,</SPAN> FeatureLayer <SPAN class="punctuation token">,</SPAN> esritRequest<SPAN class="punctuation token">,</SPAN> Polygon<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> on<SPAN class="punctuation token">,</SPAN> array
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
basemap <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"streets"</SPAN><SPAN class="punctuation token">,</SPAN>
center <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">96.68338</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">33.02529</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">18</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> sfs <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_DASHDOT<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0.25</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// First we create an empty feature collection:</SPAN>
<SPAN class="keyword token">var</SPAN> featureCollection <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"layerDefinition"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"featureSet"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"features"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"geometryType"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriGeometryPolygon"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//give the feature collection a layer definition:</SPAN>
featureCollection<SPAN class="punctuation token">.</SPAN>layerDefinition <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"geometryType"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriGeometryPolygon"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"objectIdField"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ObjectID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"drawingInfo"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"renderer"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"symbol"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"type"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriSFS"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"style"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriSFSSolid"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"color"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
<SPAN class="number token">31</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">121</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">180</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"outline"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriSLS"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"style"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriSLSSolid"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"color"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="number token">110</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">110</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">110</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.4</SPAN><SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"fields"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"type"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriFieldTypeOID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"RectangleID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"type"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriFieldTypeString"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"RectangleID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"length"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"section"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"section"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"length"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"lot"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"lot"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"length"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"space"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"space"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"length"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"spaceid"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"spaceid"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Shape_Length"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"type"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriFieldTypeDouble"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Shape_Length"</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Shape_Area"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Shape_Area"</SPAN>
<SPAN class="comment token">//featureCollection object is in the correct format to be passed in to a FeatureLayer:</SPAN>
featureLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN>featureCollection<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'myFeatureLayer'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="comment token">// fields: fields, // This is required when creating a layer from Graphics</SPAN>
ObjectIdField<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// This must be defined when creating a layer from Graphics </SPAN>
spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN>
mode<SPAN class="punctuation token">:</SPAN> FeatureLayer<SPAN class="punctuation token">.</SPAN>MODE_ONDEMAND
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">requestData</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> requestHandle <SPAN class="operator token">=</SPAN> <SPAN class="token function">esriRequest</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ab_py_wms.json"</SPAN><SPAN class="punctuation token">,</SPAN>
callbackParamName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"jsoncallback"</SPAN>
requestHandle<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>requestSucceeded<SPAN class="punctuation token">,</SPAN> requestFailed<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">requestSucceeded</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">,</SPAN> io<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//loop through the items and add to the feature layer</SPAN>
<SPAN class="keyword token">var</SPAN> features <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> attr <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//pull in any additional attributes if required</SPAN>
attr<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"section"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> item<SPAN class="punctuation token">.</SPAN>properties<SPAN class="punctuation token">.</SPAN>section<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> geometry <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">polygon</SPAN><SPAN class="punctuation token">(</SPAN>
<SPAN class="punctuation token">{</SPAN>rings<SPAN class="punctuation token">:</SPAN> item<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">.</SPAN>coordinates<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> graphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN>geometry<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
graphic<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setAttributes</SPAN><SPAN class="punctuation token">(</SPAN>attr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
features<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
featureLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">applyEdits</SPAN><SPAN class="punctuation token">(</SPAN>features<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">requestFailed</SPAN><SPAN class="punctuation token">(</SPAN>error<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'failed'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>featureLayer<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>featureLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>body</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>claro<SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>map<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="style-attr language-css token"><SPAN class="attr-name token"> <SPAN class="attr-name token">style</SPAN></SPAN><SPAN class="punctuation token">="</SPAN><SPAN class="attr-value token"><SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN>900px<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN>600px<SPAN class="punctuation token">;</SPAN></SPAN><SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>body</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
