Hey there,
I'm trying to use the addAttachment method introduced in 4.9, but it always returns an error:
Unexpected token < in JSON at position 0
even if the operation is successful. That's all I get returned from the call, but if I look at the network traffic I can see that the call was successful but is returning HTML when JSON is expected.
Here is my code for the call, basically copied from the doc:
FeatureLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addAttachment</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">,</SPAN> form<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'added successfully'</SPAN><SPAN class="punctuation token">,</SPAN> result<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">catch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>err<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'err'</SPAN><SPAN class="punctuation token">,</SPAN> err<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>The FeatureLayerEditResult that is returned is always an error, even though I can see that the operation was successful and can access the newly added attachment from future attachment queries.
Do I need to explicitly request a JSON response somehow or something?
