I'm converting an older GP task made using MB to Python.In the original, data was saved to disk (.shp) and rendered with a layer file (.lyr). Labels were displayed in the output. I've updated the .lyr file to work with an in_memory layer (longer field names). Here is the code:import arcpy arcpy.env.workspace = r"C:\gis-ags\src\gp" # temporary date_range = "\"OBDATE\" BETWEEN date '2008-01-01' AND date '2008-01-03'" # Script arguments #date_range = arcpy.GetParameterAsText(0) if date_range == '#' or not date_range: date_range = "\"OBDATE\" BETWEEN date '2008-01-01' AND date '2008-01-03'" # Local variables accum_table = "in_memory\\accumulation_table" stat_table = "in_memory\\stat_table" db_table = r"C:\gis-ags\src\gp\gisselect_cdo.sde\GIS.DAILYSNOW_GP_DATA" # Table Select arcpy.TableSelect_analysis(db_table, accum_table, date_range) # Summary Statistics arcpy.Statistics_analysis(accum_table, stat_table, "NAME FIRST;STATE FIRST;SNOWFALL SUM;LATITUDE FIRST;LONGITUDE FIRST", "COBAN") # Spatial Reference sr = arcpy.SpatialReference() sr.factoryCode = 4269 sr.create() # Make XY Event Layer lyr = "accum_xy_layer" arcpy.MakeXYEventLayer_management(stat_table, "FIRST_LONGITUDE", "FIRST_LATITUDE", lyr, sr) # Symbology symbology_layer = "accumulation.lyr" arcpy.ApplySymbologyFromLayer_management(lyr, symbology_layer)
For some reason, the labels are not getting displayed when I run in the ArcMap Python Window.Am I missing something?Thanks,Glen
