I am attempting to write a script so that instead of hardcoding the name of the new field as "CONFIVALUE" for the confidence value, I want to use the name of the third column in the header of the input text file.
For example, let's say that the first line of the input text file looks like this:
Latitude,Longitude,Confidence
In this case the field name should be "Confidence".
If the first line looked like this:
Latitude,Longitude,ConfidValue
Then the field name should be "ConfidValue".
The error if i have conField indexed as conField[2]:
File "C:\Users\Aleah\Desktop\PythonScripts\Lab7_Q5.py", line 22, in <module>
IndexError: list index out of range
The error i am receiving if i remove the index is:
File "C:\Program Files (x86)\Wing IDE 101 4.1\src\debug\tserver\_sandbox.py", line 27, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\arcpy\arcpy\management.py", line 3246, in AddField
raise e
RuntimeError: Object: Error in executing tool
import arcpy
work = "C:\Scripts\Lab 7 Data\WildlandFires.mdb"
arcpy.env.workspace = work # Set the workspace to the geodatabase
iFile = "C:\Scripts\Lab 7 Data\NorthAmericaWildfires_2007275.txt"
output = "NewFires.shp"
threshold = 99
f = open(iFile, 'r')# input text file C:\Scripts\Lab 7 Data\NorthAmericaWildfires_2007275.txt in "read" mode
lstFires = f.readlines() # Read the lines of fire
conField = []
for line in f:
comma = line.split(',')
conField = comma
print conField[2]
field = ["SHAPE@", conField[2]] # represents the field names for each row in the feature class
# Process: Create Feature Class
arcpy.CreateFeatureclass_management(work, output, "POINT")
arcpy.AddField_management(output, conField[2], "FLOAT")
cursor_new = arcpy.da.InsertCursor(output, field)# add the new points that you will create to the "NewFires" feature class
f.close() # close the file
del cursor_new # release the cursor lock on the feature class
