I would like some help please.
I have an application which enables a user to draw a polyline on a map. Through JavaScript, on draw end this polyline is added as a graphic on a graphics layer. What I can't figure out is how can a user edit the vertices of this polyline once it has been added to the GraphicsLayer?
This is my code so far:
if (evt.geometry.type === "polyline") {
if (map.getScale() < MAP_SCALE) {
var symbol = new SimpleMarkerSymbol();
var fillSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NULL,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 128]), 3));
symbol = fillSymbol;
polylineLayerGL = new GraphicsLayer();
pipeGraphic = new Graphic(evt.geometry, symbol);
polylineLayerGL.add(pipeGraphic);
map.addLayer(polylineLayerGL);
pipeCount += 1;
//custAttribInsp(evt);
} else {
return;
}To edit:
function initEditor(evt) {
console.log("initEditing", evt);
// var map = this;
var currentLayer = null;
var layers = arrayUtils.map(evt.layers, function(result) {
return result.layer;
console.log("layers", layers);
var editToolbar = new Edit(map);
editToolbar.on("deactivate", function(evt) {
currentLayer.applyEdits(null, [evt.graphic], null);
arrayUtils.forEach(layers, function(layer) {
var editingEnabled = false;
layer.on("dbl-click", function(evt) {
event.stop(evt);
if (editingEnabled === false) {
editingEnabled = true;
editToolbar.activate(Edit.EDIT_VERTICES , evt.graphic);
} else {
currentLayer = this;
editToolbar.deactivate();
layer.on("click", function(evt) {
event.stop(evt);
if (evt.ctrlKey === true || evt.metaKey === true) { //delete feature if ctrl key is depressed
layer.applyEdits(null,null,[evt.graphic]);
editingEnabled=false;
var templatePicker = new TemplatePicker({
featureLayers: layers,
rows: "auto",
columns: 2,
grouping: true,
style: "height: auto; overflow: auto;"
}, "templatePickerDiv");
templatePicker.startup();
var drawToolbar = new Draw(map);
var selectedTemplate;
templatePicker.on("selection-change", function() {
if( templatePicker.getSelected() ) {
selectedTemplate = templatePicker.getSelected();
switch (selectedTemplate.featureLayer.geometryType) {
case "esriGeometryPoint":
drawToolbar.activate(Draw.POINT);
break;
case "esriGeometryPolyline":
drawToolbar.activate(Draw.POLYLINE);
break;
case "esriGeometryPolygon":
drawToolbar.activate(Draw.POLYGON);
break;
drawToolbar.on("draw-end", function(evt) {
drawToolbar.deactivate();
var newAttributes = lang.mixin({}, selectedTemplate.template.prototype.attributes);
var newGraphic = new Graphic(evt.geometry, null, newAttributes);
selectedTemplate.featureLayer.applyEdits([newGraphic], null, null);
}Thanks
frank
