Hello,I'm a newbie to ArcGIS JavaScript API. I'm following the training material provided by ESRI when I encounter a problem. I'm trying to add a cached layer as the basemap and a dynamic layer as the operational layer. The map spatial reference is defined accordingly to the base map SR and it's in WGS 1984 (wkid = 4326). However my dynamic layer is in a spatial reference with wkid = 4757. According to this llink, both of them will be displayed. However when I try:map.addLayers([basemap, operationalLayer])
only the base map appears. I check the Export call using the developer tool of the browser, and find out that my dynamic layer has the following parameters:dpi:96
transparent:true
format:png8
bbox:-19687.435903608326,15574.1782288986,79364.82173477553,50684.9208499972
bboxSR:4326
imageSR:4326
Both bboxSR and imageSR is in the map spatial reference. Does it mean my dynamic layer never gets re-projected on the fly?When I remove the base map and set the map SR to 4757, the dynamic layer appears just fine. I tried to set the imageSpatialRefernce in imageParameters of the dynamic layer to 4757, still it did not show.What should I do? Thanks for reading.
