hello
We want to display protected areas (different polygons Feature Classes), as a heatmap. Since the protected area perimeters are of different sizes, it is not advisable to convert the polygons into points (1 point = 1 polygon). In addition, the polygons overlap.
How could the protected areas nevertheless be represented as a heat map (or similar)? A perimeter-sharp representation is not desirable.
Thank you.
#Heat Maps, protected areas#
#hotspots
