Original User: alnesbitHello all,I'm trying to populate a combo box with the date values currently in my table within a personal geodatabase (not a feature class, just a table). Then the user will select one of those dates and the records with that date will be selected. Pretty simple. I have the combo box getting filled with the correct values. But I can't get the code to work for the selection and it has to do with the date formatting. Can anyone help? Private Sub cmdSelectDate_Click()
Dim pMxDoc As IMxDocument
Dim pMap As IMap
Dim UserInput1 As String
Dim i As Integer
Dim query1 As String
Dim FeatLayer As IFeatureLayer
Dim pActiveView As IActiveView
Set pMxDoc = ThisDocument
Set pActiveView = pMxDoc.ActiveView
UserInput1 = cboSelectDate.Text
If TypeOf pActiveView Is IPageLayout Then
Set pMxDoc.ActiveView = pMxDoc.FocusMap
pMxDoc.ActiveView.Refresh
End If
Set pMap = pMxDoc.FocusMap
'Define/get the table
Dim pTabCollection As IStandaloneTableCollection
Dim pStTable As IStandaloneTable
Dim pSRTable As ITable
Set pTabCollection = pMap
Dim pTableSel As ITableSelection
Dim pTableSelSet As ISelectionSet
'Get the table
For i = 0 To pTabCollection.StandaloneTableCount - 1
If pTabCollection.StandaloneTable(i).Name = "Service_requests" Then
Set pStTable = pTabCollection.StandaloneTable(i)
Set pSRTable = pStTable.Table
'make the query filter
query1 = "RequestDate = '" & UserInput1 & Format(RequestDate, "MM/DD/YYYY") & "'" 'doesn't work
'query1 = "RequestDate = #02-05-2011 00:00:00# " , this hardcoded works
'date in table and the combo box looks like MM/DD/YYYY
Dim qFil As IQueryFilter
Set qFil = New QueryFilter
qFil.WhereClause = query1
' MsgBox (query1)
Set pTableSel = pStTable
'===select the table rows that meets the query and put it in a selection set
pTableSel.SelectRows qFil, esriSelectionResultNew, False
Set pTableSelSet = pTableSel.SelectionSet
MsgBox pTableSel.SelectionSet.Count
'===refresh the view
End If
Next i
frmSelectDate.Hide
End Sub
Thanks in advance,
