Convert centroid to GPIN
Hello all,
I've been working on converting our VBA code for GPIN calculation to python. I can create a single instance GPIN via python, though really inelegant, but processing more than one is causing me a problem. I've created X and Y fields in our Feature Class.
Our original code, used in Field Calculator, is:
Dim dblX As Double
Dim dblY As Double
Dim strX As String
Dim strY As String
Dim strGPIN As String
Dim pArea As IArea
Set pArea = [Shape]
dblX = pArea.Centroid.X
dblY = pArea.Centroid.Y
strX = CStr(dblX)
strY = CStr(dblY)
strGPIN = Mid(strX,3,1)+Mid(strY,2,1)+Mid(strX,4,1)+Mid(strY,3,1)+"-"+Mid(strX,5,1)+Mid(strY,4,1)+"-"+Mid(strX,6,1)+Mid(strY,5,1)+Mid(strX,7,1)+Mid(strY,6,1)
My solution, so far, is:
import arcpy
from arcpy import env
import os
env.workspace=r"***\Default.gdb"
#set local variables
inFeatures = "FeatureClass"
XCentroid="xCentroid"
YCentroid="yCentroid"
tableField="GPIN2"
#Load values into Variables
scurfc=arcpy.SearchCursor(inFeatures)
for sf in scurfc:
X=sf.getValue(XCentroid)
strX=repr(X)
Y=sf.getValue(YCentroid)
strY=repr(Y)
GPIN=(strX[2:3]+strY[1:2]+strX[3:4]+strY[2:3]+"-"+strX[4:5]+strY[3:4]+"-"+strX[5:6]+strY[4:5]+strX[6:7]+strY[5:6])
#Delete variables
del tableField, scurfc, X, Y, strX, strY, XCentroid, YCentroid, GPIN
I have tried the CalculateField_management route, but it fails because my GPIN variable isn't a SQL statement. Can anyone give me a push in the right direction? The online code examples do not reflect a SearchCursor and an UpdateCursor function in the same listing.
Thanks in advance
