I have a script for Parcel Noticing , it uses a subject parcel, determines its size, and then starts selecting parcels within a specified radius. If 31 parcels are not captured within the initial radius, then the radius increases by 25 feet until 31 total parcels are selected. I am enclosing the script and have a question, I want to start scripting the mapping portion of the noticing and would like to use the distance of the final radius later on, but can not figure out how to capture this number. Will someone please look at this and try to provide some feedback?import arcpy layer = arcpy.GetParameterAsText(0) apn = arcpy.GetParameterAsText(1) mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames (mxd, "LAYERS")[0] def select_parcels(layer, distance): while True: print_search_distance(distance) arcpy.SelectLayerByLocation_management(layer, "WITHIN_A_DISTANCE", layer, "%i Feet"%(distance),"NEW_SELECTION") if get_count(layer): r = arcpy.GetCount_management(layer) cnt = int(r.getOutput(0)) print "%i Features selected at a distance of %i Feet."%(cnt, distance) arcpy.AddMessage("%i Features selected at a distance of %i Feet."%(int(cnt),distance)) break layer = reselect(layer, selstring) distance += 25 ## End select_parcels function def get_count(layer): result = arcpy.GetCount_management(layer) if int(result.getOutput(0)) >= 31: return True else: return False ## End get_count function def reselect(layer, selection_string): arcpy.SelectLayerByAttribute_management(layer,'CLEAR_SELECTION') arcpy.SelectLayerByAttribute_management(layer, "NEW_SELECTION", selection_string) return layer ## End clear_selection function def print_search_distance(distance): arcpy.AddMessage('Searching %i Feet'%(distance)) arcpy.AddMessage(apn) selstring = """TAG = '{0}'""".format(apn) arcpy.AddMessage("Selection string = " + selstring) if not arcpy.Describe(layer).datatype == 'FeatureLayer': layer = arcpy.MakeFeatureLayer_management(layer, 'flayer') arcpy.SelectLayerByAttribute_management(layer, "NEW_SELECTION", selstring) rows = arcpy.SearchCursor(layer) n = 0 val = 0.0 for row in rows: val = val + row.tmp_pacres n = n + 1 arcpy.AddMessage("Sum of PACRES = " + str(val)) if n > 1: arcpy.Message("More than one record found") if val <= 1.0: select_parcels(layer, 300) elif (val > 1.0 and val <= 40.0): select_parcels(layer, 600) else: select_parcels(layer, 1200)Thanks,Chad
