Hello, I'm trying to use an UpdateCursor inside of a SearchCursor to populate sequence numbers on an inspection table according to a parcitular UserID. Basically the SearchCursor iterates through a small table with a list of about 29 user ID's (the table changes over time) and uses the values in the where_clause of the updatecursor. The UpdateCursor sorts the order of the input table based on a structure number and populates the sequences from 1 to 0. Here is the code I have tried:techrows = arcpy.SearchCursor(psegGasGDB_InputPrefix + "ASSIGNED_TECHS") for row in techrows: if TechID != row.ASSIGNED_USER: TechID = row.ASSIGNED_USER where_clause = "ASSIGNED_USER = " + TechID rows = arcpy.UpdateCursor(CONVERSION_InputPrefix + "CPTestPointInspection", where_clause, "SEQ_NO; GAS_CORR_STRUCT_NO", "GAS_CORR_STRUCT_NO") for row in rows: try: print row stop = 1 row.SetValue("SEQ_NO", stop) stop = stop + 1 except Exception as e: print e logging.error(": %s" %(e)) del rows del techrows But this gives an "Error 999999: Index passed was not within the valid range". Can't figure out what I'm doing wrong...
