Hi everyone,
I’m using the Utility Network Trace widget in ArcGIS Experience Builder on ArcGIS Enterprise 12.1.
When I run a downstream trace, the results highlight on the map, but the corresponding records do not appear as selected in the Table widget.
What I’ve checked:
- Select records is checked in the Trace widget’s results panel.
- The Table widget is configured to interact with the same Map widget.
- Manually selecting features using the Select tool correctly updates the table selection.
- Tracing and selection work correctly in ArcGIS Pro using the same web map.
Thanks for any guidance.
