Hi all,
Can you help me understand which is the best tool to use for a certain query - if there is one that matches my task?
I have a large point layer, w/~7,000 points. I want to figure out how many of these points are w/in .25 mile of each other.
So far, it seems like Summarize Nearby is the best option. I did a test using the subject layer as both the Input Features and the Input Summary Features. It basically creates a buffer of .25 miles around each point, and then creates a Count of Points field in the attribute table that tells me how many points are w/in that buffer. So, if there's more than 1 point in that field, I know that there is another point w/in the layer that is w/in .25 miles.
Is that what you would do? If not, what other tool would you use? I started out w/Group by Proximity, but that just left me a little confused. It created 8 groups, based on differing proximities, but it doesn't tell me how those groups are defined, or how far away the points are from each other in each group. I wasn't able to find anything really helpful about that tool online, or any training that addresses it specifically.
Thanks!!
