So, when I export a model from Revit to IFC and then forward that file to ArcGIS Pro, it only takes what is visible in the view and the information I want.
But when I try to export directly from Revit to ArcGIS Pro, I don't have any control over the phases of a project, and it shows all elements included in the model, even the ones that are demolished. Also, with this method, it sends all the parameters included in the project to ArcGIS Pro. Is there a way to control the phases in ArcGIS, or the Revit model needs to be cleaned to avoid this problem? Also there is a way to control the parameters exported??
