The instructions for the Integrate tool warn pretty strongly against using an XY tolerance larger than that associated with the input feature class.
In my case the input feature class has an XY tolerance of 0.003 feet. This is about this width of a bacteria. It will have absolutely no effect whatsoever if I use it.
Is it really a bad thing to set the XY tolerance to something more rational (like, 0.5 ft or 1 ft) when using this tool?
Thank you,
Randy McGregor
