Hello, I'm a couple days into my transition to ArcGIS Pro. I have several MXD files, where each one shows a single Buffer polygon - (for notifying residents about upcoming zoning changes). At this point, each buffer polygon is a separate polygon SHP file.
Here are some of my questions:
Scenario 1) If I create a new project from a template (to get a new file GDB), when I Import my old MXD, will the original feature classes from that MXD get inserted as new feature classes in the new GDB?
Scenario 2) If I simply Start a new project without specifying a template, and Import the MXD, will the feature classes that show up in the new APRX file - remain the original SHP files that were present in the original MXD file?
Scenario 3) Is it possible to insert multiple Layout Views from different MXD files into a single Pro Project? If so, can someone explain the procedure?
Thanks - in advance,
Dave M
