Hi everyone,
As the title says, it appears our ArcGIS Enterprise Connector has randomly broken. Looking in the connections tab on Power Automate, the connector appears connected. Troubleshooting includes adding a new connection, testing three different logins and reaching out to the Networking group to check blocked IPs (nothing is blocked). As I understand it, a generic Client ID can now be used (arcgisforpowerautomate) rather than having to create an application on Portal with a Client ID/Client Secret. I am unable to use the connector in a flow, the error is below. Thank you!
Could not retrieve values. The dynamic invocation request failed with error: [ { "success": false, "message": "Fetching data from gis.fdacs.gov/portal/ failed. This is usually caused by an invalid authentication token that has expired. Please reauthenticate to continue. Error message: ConnectTimeoutError: Connect Timeout Error (attempted address: thenameofmyportal.organization.com:443, timeout: 10000ms) fetch failedIf the error persists, please check ArcGIS Enterprise Client ID and App Secret provided" } ].
