I've created a Feedback form for an Experience Builder that I've been working on. I created the survey in the Survey123 Connect app and was able to publish it successfully with no issues. However, once I used the Survey widget to import the survey, all the questions that had conditional viewing settings were visible.
The first question I had was based on which age group a survey participant was part of, so most of the questions will be hidden if the user is less than 13 years old (due to FTC guidelines). Therefore, we don't want any questions to be visible if the user is less than 13 years old, so I had the following code in the column labelled "body::esri:visible" to prevent certain questions from being visible. ${Age}!='<13'
This worked well and as intended within Connect, but when I imported the survey into the Experience Builder, those constraints no longer seem to exist. I also wanted these constraints to be present so text boxes for questions where people could elaborate on why they chose "other" would be hidden unless "other" was selected.
If anyone could help with any settings that need to change to make this function as intended, it would be much appreciated. I've included the .xslx form so that people can try and replicate this issue.
Thanks in advance!
