Hello! I am encountering an issue when trying to register a Postgres table in an enterprise geodatabase. I am running into the error, "ERROR 001400: Only the data owner may execute register with geodatabase."
My environment:
- ArcGIS Pro 2.9
- Postgres 15.8
- PostGIS 3.4
Background:
I have a PostGIS enabled PostgreSQL database. My database is connected to a Django application, and so my tables are managed by that application. The table I am trying to register with the geodatabase is located at 'mydatabase.public.myspatialtable', meaning that the table I am trying to register with the geodatabase is in the 'public' schema. The 'myspatialtable' is owned by my 'postgres' user. My goal is to be able to write to 'myspatialtable' from ArcPro.
Here are the steps I took to create my enterprise geodatabase in PostgreSQL:
I followed this documentation to create a geodatabase in PostgresSQL in Linux.
In the documentation, I followed steps for being both the PostgreSQL and geodatabase administrator. I ran the Create Enterprise Geodatabase tool in ArcPro, and was able to do so successfully. After running this tool I saw an 'sde' login role created. I was able to make a database connection to my PostgreSQL database successfully with my postgres user, which again is the owner of 'myspatialtable'. I am able to view my point data from the table in ArcPro. Are there steps I missed to enable ArcPro to register a table with a geodatabase?
Thank you in advance!
