hello, I would like to report a small bug with the arcgis-coordinate-conversion component from ArcGIS Maps SDK for JS.
Steps to reproduce:
1.) With a loaded map, open the coordinate systems selection and select the second option from top (in demo: BASEMAP)
2.) Open the selection and select the second option from top again (in demo: DD)
3.) See the selection - BASEMAP is still present visually, but values for DD appear.
4.) Now try to select first option (in demo: DD) - values for another system seem to be present, the coordinate system selection now shows an EMPTY field.
5.) Open the selection again - now an empty option is present as the first option.
This is only one way to trigger the bug, I could trigger it with the third option too when clicking around a bit - clicking the same index twice in a row seems to trigger it, after which clicking the first option will add the empty option.
Here is a quick video showcasing the problem:
Vidyard Recording
Showcase was performed on the component page:
arcgis-coordinate-conversion | References | ArcGIS Maps SDK for JavaScript
