There's been an issue with the current release of ArcGIS Pro where sometimes when I select a point and try to use the buffer edit tool, it fails stating incorrect geometry type. Normally, I would uncheck the dissolve option and it would work, but recently it's been failing no matter if that option is checked or unchecked.
This was never a problem in earlier releases and needs to be fixed as my work requires me to show setbacks from features that mostly get represented as points like well heads, etc.
It gives error code 1500, and this is being used on a hosted feature layer. It does not occur on layers housed in the local database.
