I am experiencing a problem with the Table widget in Experience Builder (in Enterprise 11.5) where the table is only showing a limited selection of the total fields. The fields it is showing seem to be dictated by the fields that were selected in the web map for that layers pop-up. My layer has a total of 26 fields but only 11 are needed in the pop-up. I would still like users to be able to view all 26 fields in the table. Why is this happening? Is this a bug or a known limit to the table widget?
I can see all 26 fields in the web map and in the feature layer's data tab. All fields were also set visible when publishing from Pro. All things seem to be functioning as expect with the layer until I get to ExB.
If I select 'Customize' for the Configure fields setting (Table Settings\select relevant layer\Sheet Configuration\Configure Fields), I am able to manually select all the fields and then the problem is "solved" and all fields now show (lol jk actually it introduces a new problem). When I select "Customize" though the fields reset back to default and it does not reflect the specific layers field formatting (configured in Pro and the web map). All the date fields default to MM/dd/YYYY with a randomly assigned time. I have many fields in this dataset that require only a year and it would be confusing for non-technical users to see a randomly assigned date month, day, and time. In order to prevent it from destroying my date fields I need to use the 'Use layer settings' option in Configure fields, which dumps me back to my original issue.
What am I missing here???
