The Generate Schema Report Tool works great. However, the tool currently only supports a single dataset or the entire workspace.
I would like to be able to select a subset of feature classes or tables.
Use case: I am developing an application that uses four feature classes and two tables in a very large enterprise GDB.
When migrating schema changes from the Dev GDB to Staging or Production, it could be very useful to have a single schema report for the subset for comparison using the Compare Schema Tool.
Currently, you have to run Generate Schema Report six times in each environment and then Compare Schema six times, and lastly compare file by file.
