I have two layers - a polygon layer and a line layer. Both are in the same coordinate system. I am trying the calculate the sum of attributes from the lines that intersect with the polygons. Below is a screenshot
However, the sum is not accurate. For example, here are the values of the four lines that intersect with one polygon.
And this is the result of the Summarize Within tool.
Not sure what I am doing wrong. Any help would be appreciated.
Thanks in advance!
