Recently we had a hard drive crash and lost a custom network dataset. We previously published an MMPK to our portal to use the network dataset in Navigator. We found a workflow to access the ND by downloading the MMPK, changing the file extension to .ZIP, and extracting the zipped folder. Within a sub folder "commondata" is a file with the extension ".geodatabase" that mimics the structure of the GDB that housed our ND. In Pro we can access and use the ND with network analyst, but my question is there a way to export to a normal file geodatabase and recover the actual ND? We tried to run the "Mobile Geodatabase To File Geodatabase" GP Tool, but it returned an error code 001732 Could not copy data from Runtime Geodatabase.
@RodneyConger
@robhaley
