Hi ESRI community,
I'm working on publishing a geoprocessing service (Custom Python) to a standalone server (10.91). I'm able to run the tool in ArcGIS Pro ( v2.9), but after following these steps:
1. Right click the server connection with admin permissions --> Publish --> Geoprocessing Service
2. Select the successfully run tool --> OK
3. I get this pane, instead of the standard pane that has all of the configuration options:
Some notes:
- I am able to run a different tool and publish it using this process. I'm getting this blank pane for this specific tool.
- I am not able to upgrade ArcGIS Pro or the Server version at the moment.
- I am running a standalone server and do not have Enterprise.
- I have tried publishing via a .sd file and was getting a number of errors I wasn't able to resolve.
Here's my script for context. It's a tool that allows a user to create a custom mapbook from an input polygon. It is an updated version (To use ArcGIS Pro instead of ArcMap) of this tool:
https://www.arcgis.com/home/item.html?id=3d999c5325c0450b89df46ea75e9c2fd
Again, this tool runs exactly as needed in ArcGIS Pro.
# Library Imports
import os, getpass
import os.path
from arcpy import env
from arcpy import da
import arcpy
import random
import string
def trace():
import inspect
import traceback
import sys
tb = sys.exc_info()[2]
tbinfo = traceback.format_tb(tb)[0]
# script name + line number
line = tbinfo.split(", ")[1]
filename = inspect.getfile( inspect.currentframe() )
# Get Python syntax error
synerror = traceback.format_exc().splitlines()[-1]
return line, filename, synerror
# Generates random string to be used when creating new temp layers
def random_string_generator(size=6, chars=string.ascii_uppercase):
return ''.join(random.choice(chars) for _ in range(size))
def main(*argv):
try:
# === CONSTANTS ===
tool_dir = os.path.dirname(__file__)
PROJECT_PATH = os.path.join(tool_dir, "project.aprx")
# === INPUTS ===
inFeatSet = arcpy.GetParameterAsText(0)
layout_name = arcpy.GetParameterAsText(1)
# === Sanity checks & logging ===
arcpy.AddMessage(f"Server user: {getpass.getuser()}")
arcpy.AddMessage(f"APRX path: {PROJECT_PATH}")
arcpy.AddMessage(f"APRX exists? {os.path.exists(PROJECT_PATH)}")
if not os.path.exists(PROJECT_PATH):
arcpy.AddError(f"APRX not found: {PROJECT_PATH}")
raise FileNotFoundError(PROJECT_PATH)
# === Open project & resolve layers ===
aprx = arcpy.mp.ArcGISProject(PROJECT_PATH)
layout = aprx.listLayouts(layout_name)[0]
MapSeries = layout.mapSeries
current_map = layout.listElements("MAPFRAME_ELEMENT")[0].map
index_layer = current_map.listLayers(MapSeries.indexLayer.name)[0]
# Materialize user selection as a layer (Feature Set -> Layer)
selected_layer = "userSelection"
arcpy.management.MakeFeatureLayer(inFeatSet, selected_layer)
arcpy.management.SelectLayerByLocation(
in_layer=index_layer,
overlap_type="INTERSECT",
select_features=selected_layer
count = int(arcpy.management.GetCount(index_layer)[0])
arcpy.AddMessage(f"Selected {count} index features")
# Get selected page numbers and create page range string
selectedPageNames = []
with arcpy.da.SearchCursor(index_layer, [MapSeries.pageNameField.name]) as cursor:
for row in cursor:
selectedPageNames.append(row[0])
selectedPageNumbers = []
for name in selectedPageNames:
pageNumber = MapSeries.getPageNumberFromName(name)
if pageNumber != -1:
selectedPageNumbers.append(pageNumber)
page_range = ",".join(str(p) for p in selectedPageNumbers)
output_pdf = os.path.join(arcpy.env.scratchFolder, f"MapBook_{random_string_generator()}.pdf")
# === Export UP TO DATE PYTHON ===
# OutputPDFFile = arcpy.mp.CreateExportFormat('PDF', output_pdf)
# mapSeriesExport = arcpy.mp.CreateExportOptions('MAPSERIES')
# mapSeriesExport.setExportPages('CUSTOM')
# mapSeriesExport.customPages = page_range
# MapSeries.export(OutputPDFFile, mapSeriesExport)
# === Export OLD VERSION PYTHON ===
MapSeries.exportToPDF(output_pdf, "RANGE", page_range)
# Derived Output
arcpy.SetParameterAsText(2,output_pdf)
# Two except blocks: First catches ESRI specific errors while the second will catch other sytem errors
except arcpy.ExecuteError:
line, filename, synerror = trace()
arcpy.AddError("error on line: %s" % line)
arcpy.AddError("error in file name: %s" % filename)
arcpy.AddError("with error message: %s" % synerror)
arcpy.AddError("ArcPy Error Message: %s" % arcpy.GetMessages(2))
print ("error on line: %s" % line)
print("error in file name: %s" % filename)
print("with error message: %s" % synerror)
print("ArcPy Error Message: %s" % arcpy.GetMessages(2))
except Exception:
# Runs script directly; Allow outputs to be overridden; Grabs input parameters; Runs main
if __name__ == "__main__":
env.overwriteOutput = True
argv = tuple(arcpy.GetParameterAsText(i) for i in range(arcpy.GetArgumentCount()))
main(*argv)
I'm inclined to believe that there's something in the python itself that is causing this, but I'm still unsure.
Thanks for the help
Caleb
