Does BIM File To Geodatabase have a maximum number of IFC files it can import?
I've had success adding about 50 IFC files into a single feature dataset. But with 184 IFC files, ArcGIS Pro 3.5.3 crashes. Running the command from a Python notebook from VSCode with Pro closed crashes the kernel. Both crashes happen around the same time, about 20 minutes in. The CPU isn't stressed, and RAM usage remains below 50% of 64GB at all times.
I intended to merge them all into a single Feature dataset, then create and publish a building scene layer.
